Additive frequencies
jmack
17
Is it possible to have a gearbox with a 30Hz input and 35Hz output shaft speed cause a 65Hz vibration frequency response? We have a machine with repeat bearing failures which has a dominant frequency of vibration at 65Hz which lines up to nothing else except the addition of the input and output shaft speeds??
what about the bearing failure freqs?
[peace]
Fe
"Is it possible to have a gearbox with a 30Hz input and 35Hz output shaft speed cause a 65Hz vibration frequency response?" Not in a linear system. However gearboxes are full of non linearities. Gut feel is that second order of one or other shaft is a more likely contender.
Can you post a spectrum?
Cheers
Greg Locock
Let's say the 30hz bull gear is eccentric. It puts 30-hz varying stress on 35-hz rotating pinion. That could create a 30hz varying bow on the 35-hz rotating shaft which might modulate 35hz unbalance or modulate 35hz misalignment forces resulting in 35 +/- 30.
Just a thought. One of many ways for modulation to occur.
