I found a custom addin menu someone has created. It works pretty well. It gives you an ini file that you can modify to your needs. To get it to work you have to open the .dll in SW and then it is available in the Tools addin section. My hangup is how do I get it loaded everytime I launch SW? I thought it might be because I was using a specific template, but I addedin the .dll and saved as a template. Still didn't work. I'm sure I'm missing something pretty simple just can't put my finger on it.
I'm using SW04 sp4.1
Thanks in advance.
Thanks in advance.
