I'm trying to simulate a process of deposition of melted material onto a substrate, and study the evolution of stress and strain.
I'm using *Model change add to activate the successive elements, but I'm not sure if I should be using the option "with strain" or "strain free".
The manual says that you use "with strain" if you want the elements to be strained at the moment of activation, but what strain is that?
When should you use one or the other? Any good example to illustrate the situation?
Thank you
To
Thank you
To
