Add reverse to old drill
knowlittle
Materials
Jul 26, 2007
192
I have an old corded drill, one speed no reverse. It is a low rpm (500) drill that comes handy occasionally. I wish it had a reverse switch. Internet search seems to point at reversing brush wires. Is it really this simple? Thank you.
EDIT: The wires to the brushes are too short to tap. There are 2 long wires running from the trigger to the big coil. Can I reverse these wires instead?
NO
Bill
"Why not the best?"
Jimmy Carter
Thank you for confirming it's not going to work. What about this?
Field Coil 1 ---- Field coil 2 ---- Brush 1 ---- Rotor ---- Brush 2
Field coil 1 ---- Field coil 2 ---- Brush 2 ---- Rotor ---- Brush 1
Will these two give opposite rotation?
YES
Bill
"Why not the best?"
Jimmy Carter
I hope that your brushes are at 90 degrees to the commutator. Some brushes are angled and don't work well in reverse.
Bill
"Why not the best?"
Jimmy Carter
The brushes are positioned 180 degrees apart between them. Contact with the shiny brass piece is 90 degrees. So I am good to go with the mod. Thank you.
