AD974 output fluctuates
zaknwfp
I am using AD974 to convert analog voltage from an instrumentation amplifier and send the result to PIC microcontroller. The output from AD974 fluctuates as much as 100mV. I am providing clock from the PIC by just toggling a pin on a port. My clock does not have 50% duty cycle. I have also tied the WR1 and WR2 to ground to have the latch transparent since I want to use all four channels and don't want to toggle WR1 and WR2 all the time. Any idea why the ouput fluctuates?
Are your inputs connected to anything when you measure this, or have you put locally generated dummy input voltages to eliminate any external influence?
I tried it even with a fixed voltage and also monitored the voltage with the multimeter. It still fluctuates.
Does you circuit have adequate power supply decoupling? You should have, as a minimum a local decoupling cap on each IC of about 10 - 100nF, and bulk decoupling at the origin of the supply. If your PIC has large current pulses, add a 10uF electrolytic local to the IC.
If we learn from our mistakes,
I'm getting a great education!
