Ashereng,
You are right. Each solution has pros and cons. Sometimes, there is no pneumatic or hydraulic power at the valve location, only electric. Therefore, you might have to use electric. Now, if you want the valve to fail, you can use electro-hydraulic. The fail mechanism can then either be a hydraulic accumulator or a spring inside the piston actuator.
