RVSWA
- Jul 13, 2003
- 97
For many this is a dead horse, my apologies.
I was recently provided a geotech report which stated that as long as the wall was allowed to deflect (0.002 x Height), then the active pressure may be used in lieu of the at-rest pressure provided. They go on to suggest that near the corners, (1.5 x Height), an additional uniform pressure of (10psf x Height) should be added to avoid cracking. I have complete confidence in the report, questions are as follows.
1) With a cantilevered basement wall 12feet high, do you feel that 0.25 inches is a tolerable deflection for a flexible diaphragm?
2) Would it be prudent to use the active to size the footing for sliding and overturning and only add the uniform pressure to design the wall itself?
3) Can anyone direct me to literature that would elaborate on the origin of the (0.002 x Height).
Thank you in advance.
Still looking for my favorite quote...
