Active Drawing.dtl
JasonRErtel
1
I am a relatively new user to ProE Wildfire 2.0/3.0. I need to modify our "default" .dtl file, but I cannot find where it is located. Is there a way to backtrack to the "default" .dtl file the Pro always goes to when you create a new drawing. I can opening a drawing and then open a different .dtl, but I want the drawing to come up automatically with my "modified" .dtl file.
Can anyone help?
Thanks,
JasonRErtel
It's located in the load point directory.
Heckler [americanflag]
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
Set the config option drawing_setup_file to point to your modified.dtl file
You might also want to set pro_dtl_setup_dir if you need multiple setup files for different size drawings or different units.
One thing that I should point out is that the default dtl file is only used when you don't use a template file - you will need to modify the settings in each template file as well.
