Acronyms for motor control
shahyar
Chemical
Feb 15, 2005
216
In our project the acronyms used on P&ID for motor controls are:
XGM
XSR: run status
XCR: start stop command
XA: common trouble alarm
XA: L/R status
I found these acronyms in "instrumentation handbook" but there is no explanation for them. Can anyone please explain them for me?
I guess:
- XGM repesent the motor
- The rest is self explanatory.
- "L/R status" means Locked Rotor.It comes probably from the motor protection relay. Basically it means that your motor did not reach full speed in the allowed time.It's a protection.
Hope it helps you a bit.
L/R is equally likely to mean local / remote. Perhaps not so self-explanatory.
image.php
These most likely relate to ISA standard notation. P&IDs (Piping & Instrumentation Diagrams) are typically instrumentation centered.
If there is motor control referenced on it, it is typically only as it relates to an instrumentation / SCADA or DCS system.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> faq731-376
