ACME thread vs. UNC threads
steris
I am designing a system to translate rotary motion from a motor to linear motion. For my application I can't use a rack/pinion or pulley/cable, the only thing that works is a screw gear arrangement.
I am looking at the trade-offs between using a ball-screw, ACME threaded rod with ACME nut or UNC threaded rod with UNC nut. I don't need precision or repeatability. I have a small load (only about 200 lbs). The same 6" of thread will be traversed up to 10x/day.
The ACME threads and ball screws are much too expensive especially since I don't need precision or large load capabilities. I am leaning towards using a UNC threaded rod with nut 2"-4 because of cost but I am worried about wear. Are there other options that offer decent wear resistance without high cost? Also is there anything I can do to minimize the binding between the nut & screw?
Any advise would be greatly appreciated! Thanks in advance!
Best,
-Steris
MachinaMan,
Self locking is a function of lead angle. Thread profile is much less important.
JHG
Hi drawoh,
I agree.
ACME threads are usually made as self-locking because they are a power screw. I still suggest checking for UNC because their use as a power screw is not what they were made for, therefore they won't necessarily be self-locking.
Thanks for clearing that up for me.
MachinaMan,
Whether or not an ACME screw is designed to be self locking depends on the application. I might want to be able to rotate my screw with axial force.
A UNC screw had darn well better be self locking.
JHG
Car seat actuators use acme threads routinely. Replacement parts from auto dealer stock may give you quick experience with this.
RV trailer stabilizers use acme threads. Acme threads must not be too expensive.
Ted
