Hadi Khabbaz
hello everyone,
I would like to know what is the best demister for a acid gas KO drum already being used in a Gas Refinery in order to improve efficiency.
there already are a demister pad of 4" thickness, stainless steel 316 and a 120x120 cm2 plate in front of inlet line.
approximate analysis of inlet gas (@0.68 kg/cm2 pressure and 47c temp.) would be :
COMPONENT WET (%MOL)
H2O 8
CO2 57
H2S 34
CH4+BTEX 1
TOTAL 100
SOME Info regarding the acid gas KOD:
operational pressure: 1.65-1.7 kg/cm2
operational temp.: 40-50 c
maximum flux of inlet gas: 62500 sm3/hr
total height: 3658 mm
internal diameter: 2895 mm
body thickness: 11 mm
inlet gas line diameter: 42 inch
outlet gas line diameter: 42 inch
outlet liquid line diameter: 3 inch
demister pad thickness: 4 inch
demister material: Stainless Steel 316
any suggestion for improving efficiency by changing demister or the plate !? or any other idead ...
thanks in advance for your replies.
H2O 8
CO2 57
H2S 34
CH4+BTEX 1
TOTAL 100
