JennyNakamura
Hi Everyone,
I am designing a concrete connection using HRC headed rebars with 2.25" diameter (#18). I am using App D to check concrete breakout so I can determine how deep the HRC heads need to be. According to D.4.2.2 (I am using ACI 318-02) the equations in App D for concrete breakout are only applicable for anchors not exceeding 2" in diameter and 25" embedment. I already used the concrete breakout equations to come up with a 39" embedment for 2.25" diameter anchors before I saw this. Is my analysis still valid? If not, can someone point me to some reference material as to what the proper procedure is that I need to follow?
Thanks in advance!
Thanks in advance!
