concepto.ed
Hello!
When calculating the total deflection of a RC beam according to ACI 318R19, I've followed this way: Obtain the inmediate deflection due to sustained loads (D1) and the incremental inmediate deflection due to that portion of the live load not sustained (D2). Then, to compute the ultimate total deflection of the beam do I use: Dt= Lamda (D1)+D2 or Dt= Lamda (D1)+ D1 + D2?
I understand the lamda factor as the ratio of the ultimate sustained deflection (including long term effects) to the inmediate sustained deflection. Is my code interpretation ok?. I've not been able to found a good reference regarding the use of that factor in total deflections.
Your comments will be valuable.
