kronosconcrete
- Jan 29, 2001
- 11
When designing a two way slab, does the weight get apportioned according to the ratio of the length and width of the slab? It doesn't seem the longer dimension should be designed for the same weight as the shorter dimension since obviously the shorter carries more of the load. If one uses the same w on the longer dimension, the moments would seem out of proportion. I've read the actual delegation is the inverse fourth power of the length/width ratio. That seems correct to me. Is the shorter dimension designed for actual w and the longer dimension with a reduced w of that fourth power inverse ratio? I've never been clear on how the transverse (perpindicular) direction is treated.
