1
- #1
I am attempting to determine the side face blowout strength of a HOOKED (not headed) anchor bolt in tension per ACI 318-05, Appendix D.
Equation D-18 references Equation D-17, which contains the term, Abrg (bearing area at head of anchor bolt). This term is not applicable to hooked anchor bolts.
In addition, the title of the section D.5.4 contains "headed anchor", not "headed or hooked anchor".
Does this mean that this failure mechanism is not applicable to hooked anchor bolts and therefore does not need to be checked?
It seems odd to suggest that this failure mechanism is not present in hooked bolts, but it is present in headed anchor bolts. Perhaps there is a little or no research on this failure mechanism, and that is why ACI left it out.
