This is my first time designing an AGC amp for an RF application. I'm using a commercial AGC amplifier and detector (Teledyne Cougar). The AGC amp has a 0-5V control signal, 0V is full gain. The detector has a 0-5 volt output. 0 volts occurs at -40dBm and 5 volts at +10 dBm. I want the output to be at -5dBm which related to a control voltage of about .5 volts.
I fed the detector output into the (-) input of an op-amp configured as an error integrator with a resistor and capacitor in series in the feedback loop (single pole, single zero). On the (+) input of the op-amp integrator I connected a reference voltage to set the operating level.
I followed the integrator stage with an inverting amp, A=1 to re-invert the signal and connected the output of the inverter to the AGC amp. I guess I didn’t know what to expect, but the loop does control the RF signal, but not like I thought it would. I see “pulses” coming from the detector and these are integrated into triangular waves by the integrator. These triangle waves feed the AGC amp. Looking at the RF level when the loop is operating, the level looks constant.
I though the loop would reach equilibrium and the output of the op-amp would be a steady DC level, but I guess because of the integrator it is constantly operating around some point.
Should the loop behave this way? Any explanations of insights would be helpful.
