UtilityLouie
I need help understanding the ACFM to SCFM relationship. It seems basic to me, but I think I am getting turned around.
I am doing work for a paper company and I am doing a building air balance in a paper machine room. There are a large amount of vacuum pumps that draw from this room. Let's say that I know the vacuum pumps are sized for 160,000 ACFM at -21" Hg of vacuum at the pumps. How many SCFM is this?
I have seen this calculation related to density and also temperature and pressure (without considering water vapor). The air at the pump will be moist. What the moisture is, I don't know. I am sure the air at the suction point on the machine is saturated, but at the pump the water vapor would have some super heat due to the drop in pressure. The density of dry air to that of saturated air or very wet air is very different.
Help is appreciated.
