I'm in the process of designing a small bar end grinder. The device has two casings: one which holds a gearbox and another which holds the bar to be ground. These could not be machined from one piece of material and so I need a way to fix them together so that they do not move relative to one another (i.e. thread is inappropriate)
I've uploaded pictures of the parts. The outer housing has an outer diameter of 150mm, and an inner diameter of 140mm. These are not fixed but I'd prefer them not to be too much larger for weight saving purposes.
Any suggestions appreciated
