CarlosEstinos
I've recently taken over a project at work from someone who has left our company. The project is to design and install Hydraulic cylinders onto large gate valves.These cylinders will act as actuation for the valves.
I've attached a the current circuit diagram.
If the system was to suffer from a power failure then the accumulator must fully actuate the cylinder in 35 seconds.
I'm scrutinising the schematics as I want to be sure this accumulator is fit for purpose as it will be an expensive mistake if it isn't!
Could anyone help or point me in the right direction as to what sort of calculations I need to make in order to clarify my concerns?
Any feedback on this matter would be gracefully received.
Thanks in advance.
Thanks in advance.
