cmrdata
- Oct 19, 2010
- 70
Section 911.2, item 1, of the International Fire Code indicated that "Walls, ceilings and roofs exposing surrounding areas shall be designed to resist a minimum internal pressure of 100 psf..." Could anyone share his or her thoughts on if such explosion pressure should be treated as load at strength level, or at service level?
If it is to be treated as load at service level, what load factor should be applied when performing load combinations?
