Grumman
Newbie
- Jul 29, 2020
- 3
Hello:
Can you help me?As we known,The one or more treads should be visible can be acceptable for the correct installation of Hi-lok.but,to reduce the weight,the Hi-lite be designed for aircraft,and shorter the pin.so could you please share with the standard for the Hi-lite that if the visible thread should be above the collar?or how many threads should be exsiting above the collar are standard?
