Ynot2009
- Jun 20, 2009
- 3
I am currently designing a foundation for a crude storage tank, 80+ metres in diameter and approx. 20 metres high.
Based on preliminary geotech. data, an annular crushed rock foundation should suffice.
The question i have is how are maximum settlement tolerances nominated? I believe i should pass this information on to the geotech. engineer to ensure the ground material suffices these defined tolerances?
API 653 nominates tolerances to assess in-service tanks based on evidenced and measured in-service settlements over a noted settlement radial area, however, is there any information/standard that specifies a foundation's performance specification for maximum settlements for geotechnical design? i.e. maximum uniform settlement shall be....?, maximum planar-tilt settlement shall be....?, maximum uneven settlement shall be....?, maximum differential settlement shall be....?, maximum edge settlement shall be....?, e.t.c
Other than EEMUA 159, i cannot find any other information relating to the above.
API 650 nominates construction tolerances but not foundation design performance tolerances/criteria.
Any valid assistance/commentary/guidance will be greatly appreciated.
