Thanks all, everything that's been posted so far is close but no cigar. And yes, the Endevco one is the one I found earlier and is the most complete.
I did do the work myself. That's the reason I'm looking for some numbers out there... for a sanity check of my work. I have the % difference between a stud mounted reference accelerometer and the test accelerometer for CA, CA with mesh, CA with kapton, CA with mesh and block, Dental cement, and beeswax.
This must be one of the simplest and most tested processes in the world of vibrations so I can't believe there's nothing else out there. I guess I'll start contacting the accelerometer companies directly to see if they have any more technical papers not on the web.
