I'm going to measure the acceleration from two points on steel pipeline, and build a leak locator by correlation in the first step to develop that for farther signal processing researches next.
I want to know what kind of accelerometers usually used for conventional leak detection by means of correlation and what is the required specifications (Structure\Sensitivity\Freq Range).
I found some vague information toward high sensitivity accelerometer(15V/g) with approx 10Hz-5kHz freq range.
Please advise me with some model and brand name.
Thanks alot.
Thanks alot.
