ACAD 2009 - Match properties from xref
SeanSweeney
NO
Is it possible to match properties from a specific layer in an xref drawing to your current drawing. The xref is 5 minute opening time heavy so that its a real pain to open and copy object (or Ncopy).
Cheers. Sean.
Hi Sean,
DesignCenter?
L.
ADT 2004
Its a touch long winded but if it takes me 1 minute rather than the 5 it takes to open the drawing then got to be a bonus.
Cheers. Sean.
What properties were you hoping to match? Try typing (entget (car (nentsel))) and picking an entity in the xref. This should give you a list of the entity's properties, which can be stripped and assigned to another entity that belongs in the dwg. I'd be glad to help more if you know what properties you want to match.
____________________
Civil 3D 2008, Terramodel
The properties I am after are the same as if you are using matchprop command, ie. colour, linetype, layer global width and so on, some of which I can get directly from a copy of the layer (through design center as suggested by Exxit, but not all).
Basicly I'm after a way to replicate matchprop but taking those properties from an object in Xref rather than an object in current drawing.
Cheers. Sean.
Try this... Layers, linetypes and styles need to be loaded first. It's got some problems with Mtext properties. Let me know of any bugs, I'll try to fix them.
 http://files.engineering.com/getfile.aspx?folder=5d879914-94cf-4a0d-88f6-c7f82c920012&file=MatchX.LSP
Hi Lpseifert
Loaded but get this message
Select source entity: ; error: no function definition: VLAX-ENAME->VLA-OBJECT
Any ideas?
Cheers. Sean.
Hi again
It seems to work partially by moving the entity to the layer I have created, but doesn't change the properties of the object or the layer (so doesn't change dashed to dash dot for example) and the layer which you have to make yourself also has to be set up with the correct properties, such as bylayer, colour etc.
But thanks all the same.
Cheers. Sean.
