Hello all,
After quite a bit of research I was able to solve this problem myself. For the benefit of others, I will describe the solution. Using ACAD 2005 I took advantage of the new “Fields” command and inserted a diesel function as a field into the attribute. With this I was able to call the drawing number, revision, date, drawn by, checked by, approved by, number of tabs and the current tab name (I name my tabs 1,2,3) I really like this feature of AutoCAD 2005. Basically AutoCAD filled out my title block and all subsequent sheets the second I named the file.
“Welcome to My Pursuit of Happiness…”
