Good day people,
Another question here, we're looking at purchasing a spare vertical pump for an existing service we have. However, the current pumpsets we have are all designed whereby the pump is equipped with thrust bearings which handle all the thrust..the unit the manufacturer in question is supplying as the spare is designed whereby the motor carries the thrust bearing and thus absorbs the thrust. Now in order for us to use this unit as our spare, it must be modified so that the pump can carry the thrust as we already have a spare motor which is not designed to carry thrust. The manufacturer is stating that their design is better by having the motor carry the thrust..I would just like to know if there is any truth to this?????
Thank You..
Thank You..
