SlideRuleEra
First of All - I have been particiapating in this forum for 3 months and just want to tell all of you that the quality of both questions and answers is impressive - Thank You.
I'm familiar with use of typical deflection/span limits for a steel member (1/360, 1/240, 1/180, etc.) but have not come across an answer to the following:
If the amount of defection is not a concern, what is the deflection/span ratio that would, by itself, be a limiting factor; that is greater deflection would cause permanent beam deformation?
I hope that I have state this clearly.
