briand2
- Jan 15, 2002
- 180
I am involved with a situation where some ABS pipes have failed. Most of the failures appear to be cracks starting at the end of the pipe inside solvent-welded fittings, especially couplings. The cracks run from the end of the pipe, along the section of pipe inside the fitting, and then another inch or so away from the edge of the fitting.
The service is domestic hot water (about 3barg, 65 degC).
Some people have suggested that this failure is due to either improper joint making (not chamfering the ends of the pipe, using too much solvent cement, etc). Others say it could be that the coupling has been tightened before the solvent-welded joint has cured fully.
Does anyone have views to support these statements, or any alternative suggestions?
Thanks in advance for your help.
Brian
Brian
