about thermoplastic piping design and installation standard
guanghui an
CN
who know if America or European have thermoplastic piping design and installation standard? thanks!
Google :
1 - plastic pipe institute (USA)
2 - Asetub (Spain)
PS : not really standards but standardized design manuals
What is the industry the plastic piping to be applied to, the processdetails, or above or under ground system?
"thermoplastic" is a bit of a broad definition.
Do you mean Poly Ethylene? or something else.
There are many standards for PE, mainly material specifications.
size, pressure, duty and country of use might narrow it down a bit.
@robyengIT
I have found some manual at PPI, and I also found some manual at PPFA(plastic pipe and fitting association). thanks for you prompting.
@mk3223
these plastic pipes are used in waste water treatment plant, used as chemical dosing pipes, above ground.
Thanks for your reply.
@littleinch
yes, I mean some HDPE/PVC/GRP pipes.
I know some material standard, such as ASTM standard, I want to find the general technical piping standard for HDPE/PVC/GRP pipes.
thanks your prompting.
