update:
well i learned a bit today
you don't want to get in a hurry and messup connecting wires
i managed to heat up one bank of the final drive, likely damaging it, but it seemed to work fine after i let it cool down and corrected my boneheaded mistake.
got it to drive both output transformers no problem
got the logic jumpered across to the other driver, and that seemed to work just fine, but i had no output voltage coming out of the recepticals because the 2nd board was not powered up to close the output relays and connect the secondaries to the recepticals,, but it was working
then i decided to do something nearly as boneheaded as the misconnection in the earlier step.
i decided to removed the connecting jumper from the primaries of the two transformers.
now either that is a no/no, or i had damaged the final drive in the earlier short/overheat, but the result was
not very dramatic or interesting.
several pops and that acrid smell of magic smoke!
one bank FET's of the primary inverter took a dump, it was the one i had overheated badly. so i am not sure if the earlier short had damaged it or my disconnection of the two board outputs broke the feedback or what?
so i think i am close, i just need to go find another 10 dollar inverter, and take what i have learned and try again
this time not making the earlier mistakes.
lessons learned?
1.one logic driver apparently runs two inverter sections without blowing up.
2. don't make bad connections that result in shorts of course.
3. don't disconnect the jumpers between the output transformers? (this might have caused the failure, but not sure, however all was well till i did that)
4. a video camera would have been a waste of time, all the
fireworks are contained inside the case, so you can't see the carnage.
5. got another transformer i have been needing for another project, that has a much higher chance of success, along with a pile of other useful stuff.
6. this is too much trouble!
conclusion:
i got a better understanding of how inverters work, particularly the types used in small ups systems.
i have learned a lot about what more i need to learn
and i guess that is worth the price of admission.
thanks guys
bob g
