not knowing what KUTGW means i guess it is full steam ahead
i picked the inverter with the failed fan circuit to do the chopjob on, and lifted the main board out of the case
the solder side is the exposed side, and the component side is down in the case, so in case of explosion it is well contained.
the topology is as follows as near as i can tell
working from the output back
there is an output transformer that puts out 120ac on the secondaries and input 13.5 vac no load to ~15.8 vac at 3/4 load, so i am not dealing with terribly lethal voltages here at least on the drive side.
driving the primary side are two banks of FETs each having a parallel set
each set is driven by a pn2222a and a 2907 transistor
which as near as i can make out so far make up what in effect is a darlington pair
this pair is driven directly from the logic off the processor ic.
what i have in mind on the slave board is disconnecting the logic to the darlington pairs and jumpering the logic from the master boards logic
that way one logic controls two seperate sets of darlingtons which in turn drive two seperate sets of FET's
which in turn drive two seperate transformers
now there is no feedback from the second transformer output so i will have to parallel connect the two transformer secondaries in order for the master to be able to monitor the combined output and make correction if the voltage goes high or low.
at this point it looks fairly straight forward, but
i am thinking i should make up a tree type jumper set so that all the leads to both sets of darlingtons are equal length and therefore resistance.
it would appear to me that what i am contemplating doing is just doubling the same archetecture that is already on one board, they use a darlington pair to drive each bank of fet's, i am just adding more banks of both darlingtons and FET's.
i did find the current transformer and its output goes directly to the microprocessor via a couple of resistors, it might be that i can connect the slave CT back to the micro in tandem with the master CT? gotta think about that a bit more. i really don't think i will need to do that as long as the outputs are connected in parallel and not run seperately where one would have feedback and the other would be running open loop.
just got to take a bit more time to sketch up the connections from the board, double check and as the say in carpentry, "measure twice and cut once"
i was somewhat relieved to see that there is no DC/DC converter in the front section that boosted the 24vdc buss
to something over 150volts or somesuch.
working with a driver that is under 24vdc albeit at fairly high amperage is much safer poking around in
at least for me
trying to take my time, be patient and think it through well is the challenge at this point.
i just wanna do it and see what happens
thanks guys
bob g
