about ASME Angle JOINT UW-3, UW-12 ?
dooki
Industrial
The inspector stated that there is a Category D joint where the shell connects to the nozzle. However, since the shell is flat, the nozzle is not at 90° but at 45°, which, according to UW-3, classifies it as a Category B joint instead.
As a result, for NDE inspection, PAUT should be performed as required for a Category B joint, rather than UT, which applies to a Category D joint.
I need to verify whether this interpretation is correct.
Could you provide assistance with this matter?
dooki - there are some very experienced vessel engineers on here so maybe better cancel this post and post on Boiler & Pressure Vessel Engineering.
My only comment is if it is classed as an "Angle Joint" then see Table UW-12 - no RT/UT required.
thank you. i always respect you guys who give a answer for someone!
I don't follow this reasoning. I agree with the AI....Cat D. I would classify this as a corner joint. Unless you have some info that you are not sharing.
Neither of these are "required" by Code.
Visual Examination (NDE) is required.
