ABB 07 KR 264 1
pmilovan
My name is Predrag from Serbia and I have a problem with ABB PLC 07 KR 264.I need software for label 907PC332 with him. It is possible to connect to a 07 KR 264 with a PC without that programming console 07 PG 201 ?Do I have to help? Greetings.
Contact your local AB Representative and purchase what you need.
Oops...
I mean your local ABB Representative and purchase what you need.
Sorry...
If anyone else has any suggestions for the problem. I have not decided anything yet. Greetings.
Could Skogsgurra lady appeared on milovanovic.pedja @ gmail.com, I think I can help.
Could Skogsgurra to call me at Milovanovic.pedja @ gmail.com, I think I can help.Sorry.
pmilovan
I am not in my office and have no access to ABB stuff. But I could contact the former head of the ABB technical service department. He may have some information that can help you out.
Would you like me to do that?
Gunnar Englund
I have contacted him (Sture Erixon), waiting for an answer.
Gunnar Englund
Sture doesn't immediately recognise that part/system. Is it a PLC700 system? He asks. If so, it is probably more than 30 years old. Not many (if any) left that can handle it.
Gunnar Englund
It is a series Procontic K200 produced 1990-2000, and has a label on it ABB PLC 07 KR 264, is used to label 907PC332 Software. PLC is programmed using the console labeled PG 07 two hundred and first I do not have the console but I will use the PC and it runs under DOS. It is necessary to program the machine readout because the battery seems ruined. Without the program machine is worthless. Thanks for the effort. The image is attached to the PLC.
 http://files.engineering.com/getfile.aspx?folder=16b21030-624a-4c07-9387-7b57077206f5&file=07KR264dR1.jpg
Is there any new information?
