ABAUS UEL Subrotine_Abnormal termination signal_signal 6
Msekh
11
Dear All,
Good day..
I would submit a well known error that I got in my run of the UEL subroutine which has additional dof. the error is:
Abaqus Error: The executable /parrot/apps/abaqus/6.11-2/exec/standard.exe
aborted with system error "Abnormal termination signal" (signal 6).
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
Noting that the initial values of RHS and AMATRX are correct!
Your inputs are highly appreciated
Best regards
Msekh
