Edward7899
Student
Hi all,
I have been using Abaqus for a relatively short time, and I am using it to simulate the effects of the variation of three different parameters on the collapse capacity of subsea pipelines. This will involve first indenting the model, and then seeing how these indentations/imperfections affect the collapse pressure/capacity.
I am currently trying to script this so that roughly 150 simulations of indentation will be undertaken (3 values of parameter A, 7 values of parameter B, 7 values of parameter C). (so there may be 150 simulations of indentation and then 150 more simulations of collapse to find what pressure the indented models collapse at)
As part of this, I need to extract and analyse data relating to the size and shape of the 150 indentations. Do you have any recommendations or pointers on how to do this? And how to post-process this information to find out the dimensions/shape of the various indentations?
I have thought of creating a node set around the area to be indented, and then using the coordinates of those nodes (before and after indentation) to get the size/shape. But, this will result in a large amount of information due to the number of nodes, and I was wondering if there may be 'simpler' way that is less computationally expensive. I understand how to automate the 150 simulations, but not the best way to collect the desired info.
I have attached a photo of my indentation model for reference. (The node set I planned to take coordinates of is contained within the two datum planes either side of the indenter)
Many thanks.
Many thanks.
