Peterle123
Aerospace
I am currently using Abaqus Explicit to model a Drilling operation for a composite. I want to evaluate the delamination that occurs during this process.
I modelled the Cohesive Behaviour with cohesive surfaces and use the interaction menue to connect the two plies. I used Surface tu Surface, Surface to Node Set, as well as General contact method, but when i start the Job I get this Error message and the Job will abort:
" Surface based COHESIVE BEHAVIOR cannot be used for contact pair interactions"
The Properties for the cohesive Material are in the picture below (Cohesive Behaviour is on Default). When I Run the job without the Interaction, there is no Error, so I think that my Interaction is somehow wrong. Can Anyone Help me?
