ABAQUS - ERROR: There is only one excessively distorted element
mech_engineer
3
Element deletion issue
Hi everyone,
I am currently having an issue with the error shown below. ERROR: There is only one excessively distorted element. I am trying to model a fiber optic cold drawing simulation. I have three materials hair fiber, intface and polymer matrix.
The model should be producing fragmentation in the fiber. However, the model fails below no matter what parameters I change, I think I should be able to delete the distorted element and that should be the fragment location?
Inp. file is attached, any help is appreiacted.
**ERROR: Excessive distortion of element number 1268 of instance PART-1-1
***ERROR: There is only one excessively distorted element
***ERROR: The fatal error will generate a new field output in the last
increment. All variables applicable to the current procedure and
material type(s) will be written to the output database.
***ERROR: Excessive distortion of element number 1268 of instance PART-1-1
211993 2.007E-01 2.007E-01 00:29:01 1.000E-14 579 2.544E+06 7.466E+04
INSTANCE WITH CRITICAL ELEMENT: PART-1-1
A special ODB Field Frame with all relevant variables was written at 2.007E-01
THE ANALYSIS HAS NOT BEEN COMPLETED
 https://files.engineering.com/getfile.aspx?folder=57d877c6-d9db-406b-b9c5-448b3fa2cb27&file=Job-4_STATUS.inp
Distorted elements usually have determinant of Jacobian almost null or even negative which may cause numerical error in the analysis. Guess you should create a new mesh without distorted elements.
