O. Beckmann
I was wondering if anybody would be willing to share their input data for ductile and shear damage initiation (tabulated data for strain rate, stress triaxiality and eq. plastic strain at initiation for ductile damage and strain rate, shear stress ratio and eq. plastic strain at initiation as well as ks-factor for shear damage) and damage evolution for mild/constructional steel (preferrably S355, but any data to start with is welcome).
I understand that the data needs to be obtained from / calibrated to specific material tests like dog bone tensile tests or special triaxiality tests. Unfortunately, I do not have such test results (yet). I do have tensile test results (sigma-epsilon curves) which I could use for some adjustments to the simulation damage parameters, but I am sure that such simple tensile tests are inadequate to try to prepare a full set of input data for the damage model in ABAQUS.
The purpose of this approach is to prepare an initial simulation of a structural steel test setup in order to have an estimate of the expected outcome. Before carrying out the actual bigger scale test, I could do some more material tests to verify or adjust the material data.
I hope that somebody can help out and is willing to share their work as a starting point.
Best regards and greetings from Germany,
Oliver Beckmann
Oliver Beckmann
