Hi. Im trying to simulate crushing of a porous material by using SPH in abaqus. I've imported the porous material from an input file, and the porous material is based on PC3D particles with an orphan mesh. I've also created a cylindrical rigid body indenter which acts as a piston. The rigid body is assigned with a reference node at its bottom face, which is given some initial velocity so that the indenter will press the porous material during the analysis.
The problem with my simulation is the following: instead of compressing the particles, the rigid body penetrates completely into the structure. I tried to create a node-based surface as suggested the abaqus documentation (Link[/url]https://abaqus-docs.mit.edu/2017/English/SIMACAEMODRefMap/simamod-c-nodebasedsurf.htm#simamod-c-nodebasedsurf-t-CreatingANodebasedSurface-sma-topic1), but when I ran the model I encountered the error: Node-based surfaces are not yet supported in Abaqus/CAE, and abaqus automatically converted the interaction setting to general contact with all*. I would be massively grateful if anyone can give me some pointers to solving this issue.
