Hi all,
I am designing metal forming equipment where some machine components needed to have very high tensile strength (and therefore high fatigue strength). The components in question need to mount forming dies into restrictive spaces, so what I need is the highest strength steel that is generally available.
AISI D2 tool steel is my first choice, but I want to over-temper so that the ductility is increased. Ductility is an issue as there is not much room for large fillet radii; plus also I need to tap threads and I do not what brittle threads.
I think that tensile strength is the key performance parameter, rather than shock resistance in this application.
My question is - does anyone know of a good tool steel reference for ultimate tensile strength (or fatigue strength) versus hardness in an over-tempered condition? I would be interested in either A2 or D2, or any other recommendations.
I did manage to find two data points for A2 in "Tool Steels", Roberts, Hamaker, Johnson. They give ultimate tensile strength (UTS) of 269,500 psi and 54HRC if tempered at 1000 F. And for tempering at 1100 F they give: 47HRC; UTS is 232,600 psi; yield strength is 184,000 psi; elongation is 5% and reduction of area is 13.9%.
Of course, I found lots of data for 58+HRC and I found several references for compressive strength but the tensile data for over-tempered condition appears sparse. Therefore, I wonder if the data is actually that simple to chart UTS vs HRC. Can UTS be determined without specifying the exact heat treatment process - single vs double temper; temper time and temperature?
Any comments or references are appreciated.
ERT
ERT
