if ur pressure is not more than 500 psi then u can use a-216 wcb valves, 150 or 300 class, but if u would like to use more than 2000 psi u have not any other option except a-105 forged steel valve,
a-216 valves are avilable and manufacture from 150 class to 600 class
means max working pressure is 900 psi
and a-105 forged steel valves are manufactured for 3000 psi, 6000 psi, 9000 psi, and 12000 psi,,working pressure,,
after that pressure there is no more option excepth needle valve.
