we are designing a government office building in an area of low seismic and wind loads. so we picked a lateral resisting system with shear only connection between beam and column, and a diagonal brace between them as shown in attached pdf.
I have some questions:
1. is this a right computer model for the framing (in pdf file)?
should I use fixed connection for column to footing?
Does H/400 drift limit for wind sounds right?
2. The wind load will control the design but I still have to add those seismic information in structural notes. so
What is seismic force resisting system per ASCE 7 Table 12-2-1 for such framing?
Building frame system:
steel eccentrically braced frame, non-moment resisting,
connections at columns away from links,
or Ordinary steel concentrically braced frame,
or Steel System not specifically detailed for seismic resistance...?
Thanks.
Thanks.
