Is there anybody there knows how I can amplify a signal with a simple op-amp (CA3140 or 741) with a variable gain which is controlled by a digital signal? Nothing extreme, i.e. signal in the range of mV and gain in the range of couple of hundreds, so output in a range of couple of volts. It should be a MOSFET somewhere in the feedback circuit that its resistance changes with voltage or maybe a more intelligent way ... I'm looking forward to hearing from you.
Thanks for any help, in advanced.
Cheers
Zimbali
Cheers
Zimbali
