If I were to mount a mini-jet engine vertically and direct it's thrust (say 100Lbs) through nozzles at the end of a pair of rotors, via a rotating swivel joint, could I make a mini helicopter capable of lifting someone? The idea being that there would be no torque reaction and only one moving engine part. I guess the question is- would 100Lbs of thrust acting on the ends of the rotors be enough to produce the required lift? (say 300Lbs load) If not, how much thrust would be required?
Anybody care to make an educated guess? I just thought it might be a neat way to make an ultralight flying machine.
