A CAD program software
EngineeringDr
CA
Is there a software that comes with a large library of pre-built 3D models of engineering components and assemblies? For example, in mechanical engineering; we frequently use:
gearboxes (assembly),
cam-follower assembly,
turbines,
pumps,
heat-exchanger,
conveyors belt, chain,
equipments like cranes, excavators,
It would be great if the software comes with these pre-built categorized
PhD Mechanical/Industrial Engineering
Licensed professional engineer
IRstuff said:
but it's likely that any component you find is a point design.
Thank you for your response. It is mostly parts/components, usually assemblies are of low quality or not working.
I am looking for a pre-built library that is offline hopefully it comes with the software itself.
There is no business case for a CAD software company to do this because the effort is large and neverending and the risk is high.
Not to mention that drawing standards differ from user to user, so a single CAD component wouldn't satisfy more than a few users. Additionally, the effort to alter a CAD design to fit some other design point is non-trivial; I've seen components for cars where each car model from the same car company has a different component configuration. Even the "simple" gear can be designed quite differently, even with the same radius and tooth count.
TTFN (ta ta for now)
I intend to use it for educational purposes and not looking for the industrial complexity
No. Aside from the maintenance and quality nightmare that would create for software companies, users would also end up with petabytes of mostly useless data.
Major manufacturers and distributors like McMaster typically have free online CAD libraries where you can quickly/easily download models. If you cannot easily locate a company's library, a quick email with a part or model number is usually all that's needed. There's also Grabcad, 3dcontentcentral, and several other websites where you can download mostly hobbyist models, some free and others paid.
When I was still working for Siemens and supporting the NX community, when people asked us about 3rd party sources for models of standard parts, beyond what was being shared in the NX user community itself, this is the site we generally recommended:
Disclaimer: I have no business relationship with PARTsolutions, however, when I was still working, I was acquainted with the founder, and on more than one occasion, I've shared the stage with him or another representative of the company, at various engineering conferences and trade-shows.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
UG/NX Museum:
