Suggestion to rmarotta (Electrical) Nov 23, 2003 marked ///\\I'm an A/C contractor in Florida, and I like to tinker. I thought I'd work on the unit at my home to see if I might increase it's efficiency.
I have a 5HP/230V VFD and a 3HP/3ph compressor available to play with. Since available power is only single phase, I think I'm correct in assuming that the 5HP drive should be adequate.
///Single phase versus three phase would not be a good correlation between 5HP and 3HP, since there are very efficient phase converters for AC-DC-AC conversions. 5HP VFD has sufficient capacity to power 3HP motor.\\Now, if I disregard the cost of these components, I just wonder if it would be worth the trouble to try it.
It is more important to find out how the VFD parameters will meet the motor application including load requirements.\\Can I expect to get any noticeable decrease in power consumption?
///It depends on the motor load nature.\\
