A-182 F-53 super duplex STAINLESS 2
retthib
Petroleum
An UT thickness inspection crew took thickness readings on a A-182 F-53 super duplex 8" reducer. At the time of inspection, the material wasn't known. The crew calibrated to S/S and achieved a reading of .138". I knew that wasn't correct. I had them calibrate to C/S due to the fact of the material being magnetic and achieved a reading of .375". At that time they achieved proper readings on same. Why is the material called S/S yet has a carbon make up? Is it because of it's corrosion inhibitor factor?
API-510 cert # 32890
retthib;
Your assumption is not correct. The F-53 is a super duplex stainless steel that contains ferrite/austenite. You need to have a calibration standard for this material. You just got lucky because the ferrite in this material responded like ferrite in carbon steel. You need to have a calibration gage made out of F-53 duplex ss.
Yes we are working on that, just was wondering why with a material name S/S we achieved a more accurate reading calibrated to C/S. I figured it was due to the carbon content, but thanks for clearing that up.
retthib,
The "duplex" in duplex stainless means that it has the best characteristics of both the carbon and "stainless" worlds.
From what you have said, I believe that you consider the word "stainless" to mean an austenitic (non-magnetic)material.....Not true
The current meaning of "stainless" as I understand it, simply means that it has a certain minimum percentage of chrome and can be of austenitic, ferritic or martensitic structure.
-MJC
retthib,
How do you know that the 0,375" reading is accurate when, in response to metengr's sound (no pun intended)advice to obtain a piece of the same material of known thickness from which to calibrate, you are still "working on it"? Or perhaps there is a typo somewhere in your description?
I am not saying that the figure of 0,375" is neecesarily wrong (or the 0,138" right), but something is definitely amiss when by recalibrating for carbon from stainless (nominally a maximum velocity change of about 20 - 25% with mild steel at 5960 m/s and 410 stainless at 7390 m/s)your UT crew gave you a reading variation of 0,138" to 0,375", i.e. some 270%!
I would be more worried about what that UT crew is up to than anything else!
Nigel Armstrong
Karachaganak Petroleum
Kazakhstan
