rlflower
- Jun 21, 2002
- 126
I have posted this on the Civil section as well...
This figure defines the value "H" as the overall height of the slope, and "H/3" as the required distance to daylight.
I need to clarify the term "H". If it is to be defined as the total height of the slope from the bottom of the creek bed to the top of the ridge, then the "H/3" requirement would often be far too large to be acceptable. However, if the term "H" is defined as the height between two relatively level areas, then I would need clarification on just how large these level areas have to be in order to be considered effective.
My clients are anxious; the way this is interpeted has a very large effect on the cost of the project. (you know how it goes).
-Richard L. Flower, P. E.
