Hello all,
new member here. My senior engineer seems unsure as to the answer to my question so i figured i'd try it here.
I have a client that wants to add a low impedance Bus differential relay for an expansion project adding a bus with a 138kV breaker.
The problem comes when trying to connect the TX's CT's for the zone scheme of the bus protection. The TX does not have any more free CT's for use. do I:
A) daisy chain off of an existing protection CT?
B) is it a problem that they have different CT ratios?
C) Can i use the TX's low side CT? what ratio should this be? can it be different than the other CTs used for the bus protection scheme?
